Submariner70
Member
I have an Unrooted Droid Incredible 1 running 2.3.4.
For the longest time I can't send video via MMS Text any longer than about 5 to <10 seconds long.
I have the following settings for my video:
Resolution- CIF 352x288. Due to setting it any higher increases resolution and would definetly not allow me to send video.
Storage to storage card.
Encoding type- MPEG4
Recording length- No Limit
Under my Messaging settings I have Size Limit set to 1.23M, which is the max setting on my phone. I thought there used to be a "No Size Limit" option, but guess that changed, or I could be mistaken.
I also can only send MAYBE 3 pictures per MMS message.
My settings for my camera are:
Resolution- 5MP
Quality- Fine
Widescreen- Resolution 5.3(Widescreen) checked.
I only listed the settings I thought were applicable.
I called Verizon Tech Support and to no surprise they had no answer as usual.
Any help would be appreciated, thanks in advance.
Resolution- 5MP
Quality- Fine
