Help Camera burning my battery
rcarruba
When i look to see what is using up my battery, it appears that everytime it says that camera is around 45%. I have checked everywhere i know and it does not appear that my camera is running..... Any suggestions...:)
Read on the very top of the screen - it indicates "XX since unplugged." Power off & on your phone and go immediately to the battery use sub-screen. Betcha it says 100% Android System now.
your fb app eats alot of battery if its not completely closed, you must exit out of all your apps that you are not using to get maximum battery life....dont know how to close out all your apps? instructions at HTC EVO 4
