saptech
Android Expert
I've been using this app Camera FV 5 on my phone for over a month and think it is a pretty good app. I recently decided to try it on my Tab 2.
https://play.google.com/store/apps/...a.lite&feature=nav_result#?t=W251bGwsMSwyLDNd
A problem I'm having is it will not snap pictures when the reddish rectangle box appears (autofocus, I think it's called). Everytime I snap a picture, the autofocus box turns reddish and will not snap.
I emailed the developer about it and he said he hasn't seen others with this issue.
Could someone with a tab 2 try this app and let me know if you're having the same issue?
Thnx.
Thnx.
