Welcome to Android Forums.
Your Kocaso tablet might be having a problem recognizing you SD card.
This is usually due to one of two problems.
1. You have somehow managed to corrupt the SD card (i have done it twice myself). Pulling the SD card before un-mounting it, pulling from computer before it is safe to remove, etc.
2. The SD card reader is going south.
To fix the first one just unmount, pull, and place into your computer. Transfer all data to a folder on the computer.
Go to: Start/Computer. Right click on the icon with the drive letter for you SD card. Select to format. Make sure you format to default settings. Safely remove from computer and put back into tablet (it should auto mount, if not mount it).
Reboot the tablet. Un-mount the SD card and insert into computer. Transfer all data back to the SD card.
For problem number 2 you will need to take back to store or get an exchange through the manufacturer.
Note: it could be the camera app is messing up as well. Try one from the PlayStore to see if it fixes the problem.
