Help Camera issue after Verizon firmware upgrade
raiden2507
Dear All, my Casio is finally working fine with the latest Verizon 4.1.2 firmware: I am able to browse by setting the right APN.
The big problem is the camera because anytimes I start that module I get the error message about "Unable to start... please wait". I tried to uninstall the Camera app by using the several apps and now it shows a different error message but as the system now finally works, how can I fix that problem without install a new firmware?
Thanks.
Try clearing the cache and data of the camera app. If it still doesn't work then it will be more difficult. Are you rooted? If so maybe you could remove the camera with titanium backup and then have someone post a backup of their camera apk and then you could install their backup using TiBu.
If you are not rooted then maybe download the Google Camera from the Play store. It's not a great camera but it is better than none.
Dear rjglenn,
first of all thanks for your support. Yes, the device is rooted, I removed the camera trying to re-install it but it didn't... can you give me a backup of that app to restore by using TiBackup?
Also wiping-out the cache it doesn't work... but it is about the Verizon firmare?
Regards,
I'll post up a dropbox link in a bit. I'm at work and I have some stuff to do then I'll get it for you.
Hello,
I tried to launch id directly and it shows me the following error "cannot install the package".
How do I do to install it via TiBk? Can you make a backup of your app?
Cheers
Unzip the contents of the attached zip into your titanium backup archive and then restore it from TiBu. If it does not work then use TiBu to uninstall it, reboot, and then install the apk provided by JKH62. If that doesn't work the I don't know...
First of all thanks for the wonderful support. I did it and it shows:"Can't connect to the camera."
If I try to load another app for the camera I get:"Failed to start the camera. Please wait a while then try again.".
Now I will un-install all and I will try with the suggested trick.
P.S: Meanwhile... thanks!!!
Hello,
unfortunately... it doesn't work.
Same error code and if I try example with Camera FX, I get this message:"failed to connect to Android camera (error 1). What's can be happened?
Regards,
Have you dropped your phone? This is beginning to sound like a hardware issue. Try one of the bar code scanner programs to see if the camera will work at all. If no application can find the camera then it may have somehow became disconnected from the motherboard.
What RJ said....sounds like a hardware issue / fault if no app works or sees it.
Good morning and thank to all... maybe the problem could be the firmware? I did a wipe-out for a full restore and it happens again. It's the Verizon firmware 811: with that one I am able to use the 3G network with the stock not.
Which one should be the firmware to use with my device exactly? Mine is the Casio CA-201L.
I have been having an issue with the camera since the update before this. I am not rooted. camera works fine until an app like ebay or walmart wants to access the camera then it freezes. One more year then I can get a nexus 6 or samsung galaxy.
