Camera lens protector!
backdown
Okay, so today i bought a invisishield screen protector for my evo. I didn't like how it went on and everything, so i threw it away. i started to think about it, and cut it in half, and then in half again. I took off the battery cover and laid it over the lens. Put the cover back on and you can barely notice it. It is worth it for 14.99 to me, and it might be to you, especially if you can find a clearance one!
I like that idea, but i think i like mine better (minus the price). The cover over my lens feels soft and rubbery, where the one he put on you think would be all crinkly and that junk, and you would hear it.
Thats gotta reduce your image quality by alot.
I got the standard 2 piece hard case (the one with red, blue, gray parts) at the sprint store and this protects the lens because the opening is taller than the lens.
