Root camera or gallery problem
I had problems with running the blur camera with the asop gallery.
Switched to blur gallery and problems are solved.
The AOSP gallery is on the new apex rom right? Im having some issues as well.
basically when I open the gallery sometimes the pictures dont show up and I have to open the gallery again. Is that what you were experiencing?
How do you go about switching back to the regular blur gallery?
From Fabs Apex 1.3 original post
Scripts: Use in terminal emulator or through adb. For installation, removal, and switching of apps. To get a detailed description of what each script does, just type the script without any modifiers into terminal emulator. The dashes are to be ignored (they are pseudo bullet points).
Switch Apps:
-alarm
-carhome
-email
-gallery
-keyboard
-messaging
-nexus
From Terminal Emulator on Droid type
gallery -mot
switches to motoblur gallery.
Give it a shot, seems to have worked for me. I was having problems with saving as well. Seems like the pictures would show up later, as if it was taking a long time to save. I could see the picture I just took in the little preview window, but when I clicked on it and went to gallery the picture wouldn't be there. I had a couple of instances where the screen turned black after taking a picture and had to hit home button to escape out. So far so good with blur gallery, and I do have location enabled.
