Help camera question
bradm23
Member
how come when I tap the screen to take a picture it is very inconsistent as far as when it will take and when it doesn't. Any advice?
In before move. This has been a problem for a while. You have to press the screen till the green box shows up then hold inside that green box. I had suggested someone can make an app that would allow us to turn the phone on the other side and use the + volume hard button for taking pics but no one seemed to care.
