So, from experimenting with the camera, it is clear that the software applies a noise and/or blur filter by default (i.e. sharpness setting of 0). When setting the sharpness to +2 the pictures come out with more actual detail since it no longer applies those filters. The same applies to the video camera as well.
The big problem is that the camera app will not remember the sharpness settings after exiting. I've tried other camera apps, and while they do not apply the noise/blur filters, they all have other issues. Simply put, none of them work as well as the Samsung app (especially the video portion).
Is the common with Samsung camera apps? Is there a workaround? If rooting is required to fix it, I have no problem doing that.
Any help would be greatly appreciated!
