Help Camera sound help ICS 4
gordo01
I have upgraded my GT-I9100 to ICS 4. The open europe version. Ive had no problems BUT i want to get rid of the bloody Camera Sounds.
Now i have been reading about the creat a file local.prop thing. But i cannot get to work,
so does anyone have any tips or apps to help. I AM NOT ROOTED. and the thing i dont understand about the local.prop thing it says create a file and add a line. Well what file do i create. a txt file ????????
I don't know what local.prop is but if it's part of the system you will need to be rooted to use it.
If you was to root it would be much easier just to rename/delete the camera sound .ogg files.
