camera
You probably rooted it and got rid of one of the system apps didn't you? I did that too...I Can't remember which app it is but one of the system apps is linked to the camera...there is another thread in here that talks about the same issue...good luck
Did the same thing..... ;) oops lol
You need a .APK installer. One like "Easy Installer" should get you setup.
Thanks for your reply.. No luck with Easy Installer - I usually use Astro to install apk's from SD card.. Could it be that the com.android.camera.apk file is corrupt? because I have not had any trouble in the past installing apk's.. Maybe someone could be so kind to upload another com.android.camera.apk from their Warp to try ;) Thanks.
