Help Can a Froyo user test Iheartradio and post
philly0128
Is there any one who upgraded over the weekend w/ froyo that has iheartradio install, I would like to know if anyone else is having problems getting it to work, today all mine is doing is saying connecting. I've been using it for about 2 months at my desk here at work and I've never had a problem, now I am. After testing I found that I can get it to work via wifi if my signal is good, then if I turn off the wifi, it just says connecting again, and if I try 4G I only get 1 bar @ my job but it just says connecting as well
I downloaded the unoffical update, i'm still using it.
Iheartradio works on wi-fi, I turned off wi-fi went outside and couldn't connect on 3g with 4 bars... guess i've got the same issue.
I'm having the same problem with the official FroYo OTA. Well...this is my first "this sucks" moment with 2.2. Oh well...I'll just patiently await a fix...
DOA for me too. I have tried it on Stock rooted 2.2 pre-release and final, Fresh 3.0 and 3.1...same issue, no connection on EV-DO (no 4G for me), and it does work on wi-fi, but it locks up and I have to kill it.
This is one of my favorite apps, I do hope it is resolved soon...looks like it's pandora for me, at least for the time being
I haven't updated yet as i want to go with cyanogen when 4G and HDMI are working.
I still have an unrooted 2.1. IHeartRadio worked once and then never again. I emailed their customer support about a week ago and have not even had an automated reply.
I've found a work around to get IHeartRadio to work after FroYo on the EVO.
If you start IHR, and then turn on WiFi (you don't have to connect to a network, just turn it on), IHR gets past the "connecting" point, and works.
You can then turn off WiFi.
This bug is a big PITA, but with WiFi tether working, and this work around, at least now I don't have to keep going back to 2.1 just for IHR
I just loaded the new Andorid upgrade to 2.2 and IHR no longer works over the air. Works fine on WiFi but not over the air (of course I don't need it via WiFi). Exact same problem that everyone has already posted. IHR worked fine prior to my Android 2.2 upgrade today.
Still on 2.1 - the turning on wifi trick didn't work for me - although IHeartRadio does work on my wifi network at home. I would like it to work on either 3G or $G elsewhere.
I might think Sprint is disabling it, except they let other streaming apps connect so why would the single out IHeartRadio?
I tried Axlrod's workaround (see above) away from my WiFi connection and it worked perfectly. The only thing different from your experience is that I had to leave the WiFi connection on. Thanks for the tip. My IHR talk radio is back online.
My IHR is not working now either after the Froyo 2.2 OTA.
I was working befor and I swore it worked last night.
I tried
"If you start IHR, and then turn on WiFi (you don't have to connect to a network, just turn it on), IHR gets past the "connecting" point, and works."
And that did not work for me. As soon as I kill the Wifi, IHR quits.
Seems like it's an intermittent problem with my IHR.
IHR is now working for me on 3G. Appbrain also shows an update for IHR but it cannot be found in the market. Anyone else now working on 3G or has anyone received the latest update?
I originally started using this App on the Hero and it works just as good on the EVO. It's nice to go to breakfast and read the paper and listen to local radio talk shows with ear plugs at the same time. Great App!
Jack
DOH...just messing around w/ IHR 1.5 on my Froyo phone, now it rebooted...omg is it 1995 again? Will try the verizon version next and see wha' happen. At least gnome is almost done emerging on my Gentoo VMWare box...
Version 2.2 still hangs at connecting...even w/ WiFi turned on. Trying to setup guest network access now to see if WiFi makes a difference (I don't remember it working at home w/ wifi...hmmm).
