Can an unlocked mytouch slide work for boost mobile
will the internet and all work for boost if not ill get the i1 but id rather have the slide
My guess is no.
Boost/Nextel run on an iDen network while the Slide is designed for GSM.
However Boost/Nextel did switch from the 800MHz band to a 900MHz band and that is one band the Slide uses. I believe it's 2G though so again............
My guess is no.
