Root Can anyone help me?
NPH-
I just rooted last night with the one click root thing, blah blah blah
flashed evileris4.0 and everything is working great
however, my up time and awake are the exact same and it is killing my battery life
does anyone know how to fix this?
thank you guys for your help
Perhaps try the Airplane trick. Plug in your phone, select airplane mode, wait a few minutes, unplug phone, undo airplane mode. Maybe that will work. Give it a try.
..my up time and awake are the exact same and it is killing my battery life..
Have you configured your apps, GPS, weather etc, to update in the background?
Also, have you overclocked the CPU? That won't cause uptime anomalies but it can contribute to battery drain if over done a bit and especially if no "sleep" profile is enabled with a low setting such as 245, etc.
