Root Can anyone help me??
mreel89
My I7500 won't turn on after I updated my phone trough my pc studio.. When i turn on the phone it shows "samsung" on the screen, then it turns black.. Anyone help me please??:confused:
Try going to recovery mode and try with options there.
For recovery mode press volume_down+call+power button.
Hi,
Yes do a recovery mode attempt first. If that fails, then you might have to make a gold card for your Samsung I7500. I don't know if gold cards can be made on Samsung devices as of now. A gold card is ur last resort. :( Gold cards can save ur phone.
Gold Card: How To: Create a Goldcard | TheUnlockr
It is primarly used for debranding but can work to unbrick ur device.
Let me know.
Good luck
Cool
Stinky
I tried recovery mode. And it shows a picture of a mobilephone and a triangle with a "!" Maybe i should try gold card..
WAIT!!!
That's it now hold down i think menu and then power button! <-------!WRONG!
Wait let me check quickly for you... hold on a sec
Hi again,
Try holding down "volume down" + "both call buttons"
Give it a try.
There is always a option to install Galaxo (is better then the stock ROM from Sam*censored*) or Gaosp (nightly). :D
