can anyone recommend a gamepad thats not too expensive?
james_uk
Hi, i only play games now and then on my tablet so i don't need a brilliant expensive one, i just want one that will do the job and make game playing on certain games (gta, sonic etc) better, i find using the screen all the time a bit rubbish and makes me not want to bother with the games i have.
can anyone recommend one?
james
Any recommendations? I've had mixed reviews as most people say just get PS3 controller, but then its down to the game if it works or not.
I found for better compatibility with games that support controllers, the xbox 360 or ps3 are the popular and well supported. I had a wireless xbox 360 controller, but the wireless adapter broke. Got the wired replacement instead since it was cheaper (~30 with taxes on sale), also easier to grip without the battery compartment.
Edit: at least with the xbox 360 controller for Windows, you can also use it for the desktop with games that support it (and there's quite a bit). So it's not a total waste.
