I doubt it. The casing is a completely different design. With the Desire, you can remove the whole of the back case which includes the area that houses the camera. On the Desire S, the only part of the back you can remove is the bottom third for access to the battery, SIM and SD card.
However, if you keep the lens clean and free from scratches, then you wont have to worry about this kind of picture quality issue.
