DroidsIsPerfecked!!!
Member
I have a 3600 mhz Seido battery which is about 6 weeks old, and although I did a factory reset before installing Froyo, it does not perform the same as it did before. It takes longer to reach full charge, and does not last as long. I have been through lists of currently running apps with the Android System Battery program, which does not list any power-sucking apps (Android System tops the list at 38%). Maybe I'll use Tasker to manage Bluetooth for my devices, if this can be done, as it uses 18% of my power consumption, but other than that, the only thing which I can guess may have made a difference is that I have since installed a 32G SD card. Can higher storage impact your battery consumption on Incredible?
