Can i downgrade Wildfire 2.2.1
ChryzaorFlux
Does anyone know the answer to this simple question
Can i either root or downgrade my HTC Wildfire 2.2.1
*After 6 hours*
Ok guys, I have googled soo many ways, tried soo many procedures, nearly had a heart attack because i thought i bricked my phone (reboot took way to long)
Ive decided, if you have Android 2.2.1 on Wildfire, dont try to root your phone your only wasting your time, HTC have managed to create an unbeatable patch (atm)
Hopefully in a few months or so, we will be finally able to root, but for now, im sticking with my non-rooted phone.
Peace out
Why downgrade now, serves no purpose as there is really no significant difference between the two for everyday use any way.
I dont know if you can root once 2.2 has been loaded, although i did see somewhere where it might have been done, how successfully, i cant say.
But good luck
ORA
But good luck
ORA
Well i only wanted to downgrade so i can root, my main aim is to root
theres a software called alpharevX..which turns ur S-OFF , i hv done tht n i rooted my fone through the unrevoked method...worked pretty gud! but to WARN u..alpharev is still in beta...but it worked for me
Yhh i tried that method, but didnt do it right, luckily i didnt brick my phone
Im going to just use my non-rooted Wildfire for the moment, ill try to root it maybe next week or so
Wish me luck :)
