Hi, i was wondering if it would be ok if i formatted my 8 gb sdcard thats in my rooted phone, and i also have a new ROM. or if i can upgrade to a 16 gb card. i only have 1.7 gb free.
It might help if we knew why you wanted to format but in general you can format your sd card as long as you use FAT32. I'd back up all the files and directories and then copy then back to the sd card after you format it. Hope that helps some...
-djlman (HTC Sensation with class 10 16GB SD card)
