can I print to wired printer
If the printer is connected to a network that you can access via WiFi, then in theory you should be able to access it - my printer is connected to my router via a cable and my laptop over WiFi.
Not sure what the story is with printer drivers and the Tab, though ..
You can print from any Android phone or tablet to just about any wired or wireless printer using Cloud Print, which is available in Google Play. You would also have to set it up in Google Chrome. Also, you do not have to be on Wifi, 4G works just as well.
