Can I Uninstall ICS
MrDanjer
I "upgraded" to ICS a few days ago and I don't like it.
When I choose "Combined Mail" to look at two mail accounts inboxes at once, the mail program crashes -- says, "Unfortunately, Email has stopped."
When I am web browsing the browser often closes for no reason.
The Clock app no longer shows the local weather.
The google search bar is annoying... it used to show past searches, and now it shows items in my USB storage and past searches.
Does anyone know how to go back to Gingerbread?
There's one way : root > install stock 2.3.* ROM >>> unroot !
I get this:
-- Install from sdcard...
Finding update package...
Opening update package...
Verifying update package...
Installing update...
assert failed: file_getprop("/system/build.prop", :ro.build.fingerprint") == "google/soju/crespo:2.3.3/GRI40/102588:user/release-keys" || file_getprop("/system/build.prop", "ro.build.fingerprint") == "google/soju/crespo:2.3.3/GRI40/102588:user/release-keys"
E: Error in /tmp/sideload/package.zip
(Status 7)
Installation aborted.
I get this:
(Status 7)
That sounds like you're using a 2.3.3 to 2.3.6 update, rather than the full ROM version of the update.
Based on the file you're using, I'm guessing you must have an I9020T or I9023. If that's the case, try using this update file instead: http://android.clients.google.com/p...a25375426.signed-soju-ota-189904.1ada2537.zip
Also, are you using a custom recovery image, or the stock one?
also if you have a locked bootloader (non rooted) you will have to unlock it (very simple) and flash a costom recovery wich will allow you to flash a downgrade ..and after that if you wish ,you can lock the bootloader to keep the warranty.
Ugh... I'm not very technical. I tried unlocking the bootloader (installing SDK on my computer, Java jdk-7u2-windows-x64, Eclipse, etc and am going nowhere fast.
Does anyone know where I can find an easy step by step method for:
1. Unlocking bootloader
2. Flashing a custom recovery
3. then flashing a downgrade
1.Read the #2 point and install only Android SDK [you have a link there !] ,after backing up all your data/contacts etc. power off the phone and start it by pressing VOLUME UP+POWER at the same time [keep pressing until it will start > see #2 point link] and connect your phone to the PC.
After entering Bootloader do this !
"type in CMD [START > RUN : type CMD] : "D:" and ENTER; NOTE ! : DON'T USE QUOTES " "
type : "cd android\sdk\platform-tools" and press enter / or if it does not work : "cd android" and enter , "cd sdk" and enter , "cd platform-tools" and enter;
type : "fastboot devices" [you should see some text under the line "list of devices attached" ,if YES ,your driver is OK ,if NOT ,ask for HELP]"
type : "fastboot oem unlock" > you will see THIS ,select YES [NOTE : BY SELECTING YES YOU WILL DELETE EVERYTHING ON YOUR PHONE !] > phone will reboot ,follow the link below !
2. Read this THREAD ..if you have questions ,ask me !
3. after finishing with step "2." from this post ,regardless of what you find in my other post ,move to your storage [aka usb storage/sd card] and flash [like in the tutorial] this ROM HERE [Thanx quantumrand !]
Forgot to mention, my model# is: GT-19020T
I tried the above and the Android 1.0 driver is not installed - I get this message:
Windows detected a new device attached to your computer, but could not find the driver software it needs to make the device usable. Each device manufacturer typically includes driver software of a CD that comes with the device, or as a download from its website. The hardware ID of your device is USB\VID_18D1&PID_4E20&REV_0100.
Problem signature:
Problem Event Name: PnPDriverNotFound
Architecture: x64
Hardware Id: USB\VID_18D1&PID_4E20&REV_0100
OS Version: 6.0.6002.2.2.0.256.1
Locale ID: 1033
So I went here: [Tutorial] Adb Driver Android 1.0 Install - xda-developers
Followed the instructions to edit the android_winusb.inf
Now the phone was seen by the Platform tools -- and the bootloader was unlocked
I then flashed the rom and got this:
assert failed: !less_than_int (1316544229, getprop("ro.build.date.utc"))
E:Error in /tmp/sideload/package.zip
(Status 7)
try to turn : "toggle signature verification" and "toggle script aserts" off from recovery under 'install zip from sd card' menu !
if that does not work ,try to restore THIS from backup > restore [put it under : sd card/clockworkmod/backup]
I don't get those options on my screen.
First Screen I get has these options:
REBOOT BOOTLOADER
REBOOT
RECOVERY
POWER OFF
If I select recovery, the phone displays the android on it's side with a red triangle and an exclamation mark. I hit power and up and I get the Android System Recovery <3e>:
reboot system now
apply update from /sdcard
wipe data / factory reset
wipe catche partition
I don't see anywhere to "toggle signature verification" or "toggle script aserts" off.
I also downloaded the file you recommeded, put it in /clockworkmod/backup -- but I don't find anyplace to select "restore"
_____________________________
Ok, I re-rooted the phone, then tried the above suggestions:
1. "toggle signature verification" and "toggle script aserts" off) -- they were already off
2. Downloaded the file you recommeded, put it in /clockworkmod/backup and tried a restore and got a MD5 mismatch error.
