solosaniok
Member
Will i be able to backup my Orange branded Desire ROM with ROM MANAGER if i did NOT root it????
i need the backup in case i will need the warranty!
Yes, but there are no UK orange RUUs available. The method to return an Orange handset to stock is uniquely specialised and only supports AMOLED
So what will be your advices ????
If you want to root or debrand, just bear on mind you'll never get back to orange stock
most people would consider this a god send really....orange is terrible with UI firmware changes etc...just terrible lol
If you have just got your unit then it's SLCD, if you got it in the summer or earlier last year it'll probably be AMOLED but there's no sure way of telling without getting a magnifying glass out
Oh I know. They really know how to f**k over an operating system. I bought my fiance a hero. I had to root / custom rom it just so it would accept the network unlock code.
Still not fool proof though, could have been incorrectly packed in the factory, or if you bought it second hand...
Looking for screen bleed probably is the best way![]()
Bought it sealed in the box, from an Orange shop, in September...
I'll try the screen bleed thing :?
