Help Can no longer enable blocking mode on Verizon
dylane
I originally setup blocking mode using Quick Shortcut Maker. I recently had to send my phone in for a repair, and when I got it back the phone was wiped and I had to start over. I downloaded Quick Shortcut Maker again and tried using it, but it no longer seems to work. I get an error message and the developer has a note that he is aware of the issue and is trying to fix it, but no timetable. I then downloaded a similar program called Any Cut. I'm able to find Blocking Mode in the list using this program, but when I try and create a shortcut the program force closes.
Any other way to get this feature back? I'm rooted if that helps.
