Hi all.
I've rooted my x8 in order to use link2sd as I was fed up being limited by the number of apps I could install
I have a Sandisk 8GB sd card formatted in 7GB FAT32 + 1GB ext2.
Only recently, I noticed that any files I add/remove from /sdcard aren't actually modified whether using USB storage or using android explorer.
If I delete from the PC when connected through USB, it's actually deleted but once disconnected from PC, the files still remain there. Same thing happens when using explorer OR root explorer, files are deleted and then reappears. I tried a chkdsk and no errors reported.
I'm not sure what's going on
