Help Can Not Install Mini Modular Gapps!
ettore88
Hi guys!!!I have problems installing on my SII i9100 (CM11 nightly version Apolo kernel) MINI MODULAR GAPPS.This is the error:(TWRP)
"Insufficient storage space available in System partition.You may want to use a smaller GApps(i.e. Micro GApps)
You need 94280 KB system free space.You only have 31512 KB available."
How can I fix it?
I know I can install micro gapps,but I wanted to know if there is a way to install mini gapps...
have partitioned the s2 with pit file to 4GB.
Here's the 'pa_gapps.log'
# begin pa gapps properties
# This file contains information needed to flash PA GApps
current_gapps_version=20140629
current_gapps_type=micro
installing_gapps_version=20140629
installing_gapps_type=mini
total_system_size_kb=0 9 516040
used_system_size_kb=461532
free_system_size_kb=54508
free_space_reqd_kb=85320
total_gapps_size_kb=223576
install.chrome=false
install.faceunlock=true
install.camera=false
install.gallery=false
gallery.device=none
replace.launcher=false
replace.mms=false
replace.browser=false
replace.picotts=false
device.name=i9100
# end pa gapps properties
Can I increase the system partition?Thanks in advance!!!
:D
I had the same problem with my Galaxy S2 i9100 with CM11 M10 and solved it by installing the full gapps provided by Cyanogenmod (gapps-kk-20140606-signed.zip): they install correctly with no issue.
I had tried to install pa_gapps-modular-mini-4.4.4-20140916-signed.zip and got the following error during the installation through CWM:
[HIGH]Insufficient storage space available in system partition.
You need 173816 KB system free space.
You only have 93188 KB available.[/HIGH]
Aren't the mini modular gapps supposed to be smaller the full gapps? It's weird they don't get installed while the full gapps do.
