Root can some1 help?
Looks like chrome is on the sd card, makes no sense to me that you can't get rid of it unless you're using Sepero's sd script.
I was using it but it got broken after update F. I had youtubeHd, n mapsHd inverted that i found on web.
You did OTA???
I would format my phone from root required apps/tweaks before ever doing an OTA....that's just asking for problems.
You did OTA???
I think that's what happened...
Still wrkng on it im going trough all files to find them..
Trust me their r all over
