Cbelflower321
Member
When I turn on LGNPST and plug in my phone, none of the information of my phone shows up. the model is unknown and the s/w version is ms690zv4. The version, file name, and compiled date are all blank.
- Did you turn on the phone's USB Debugging in Menu -> Settings -> Applications -> Development?
- Did you drag the MS690.dll file onto reggie.exe?
components 1.0
Components 2.0
Components 3.0
Components 4.0
Components 5.0
Help_General_Lab
Model
HardLock.dll
Hldinst.exe
instMLockDrv.exe
LGNPST.exe
LGNPST_General.exe
LGTreeView.ocx
license.rtf
license.txt
MegaLock.dll
PhoneSetting.ocx
PhoneSetting2.ocx
Skin.dll
Are you sure you didn't start the upgrade then unplug in the middle of the upgradeYes I resolved the skin.DLL issue. I have had my phone in USB debugging while trying to use lgnpst, but ill try what you said.
If it has to search for drivers each time you connect it, I'd guess they did have an issue installing. Might be your whole problem right there.Yes I can access the sd card. After installing the drivers when I plug in my phone it searches for the drivers in preconfigured folders. Did they install incorrectly, or maybe in the wrong location?
