Root Can someone make a ring unlock theme?
If you mean a ring lock screen like this:
It's Miui locker.
Just get widgetlocker thats what i use heres what my lockscreen looks like, just make sure you give it root permissions and you should only ever see the stock lockscreen for a few moments when you first boot up the phone if you reboot it or whatnot.
Nah i want cm7 ring lockscreen built into the system all them apps is cool but i dont like to go thru 2 lockscreens sometimes
View attachment 33121View attachment 33122
From what I've read in other forums, the lockscreen is so tightly integrated into the framework that you can't change it. ???
Ya thats exactly the problem, and its why the vast majority use apps like widgetlocker etc because hacking your theme into the framework is no easy task.
