I was looking for the apps that are incompatible with Froyo. I was wondering if any of the following are on there because as soon as I un-installed them, my up time compared to awake time regulated again.
Must be Yellowbook Search because I have Engadget and just this morning I did a power off\on just to make sure my up time\awake is functioning as it should. Meaning their not the same. Running Froyo.
astro has a built in task manager and those are incompatible with 2.2, but if you dont use the task manager in it, it shouldnt be a problem. i dont see how either of the others would keep the phone awake. unless engadget has an auto update feature?
