birddseedd
Member
i'm rooted with simplicity rom. seems tethering is the only thing I can not get to work.
any advice?
any advice?
In a word, "yes". I have pretty much the same set-up, F7, rooted with Simplicity rom. I use Wi-fi Tether and have my computer tethered to my phone as I type this msg. I'm on Boost Mobile.
Here are the settings I'm using to make mine work:
Device-Profile is Generic ICS/JB (wlanO)
Setup-Method is set to "Auto"
WIFI driver reload 2 box is checked
Routing fix box is checked
Hope this works for you
are those settings in wifi tether? any chance you can provide a link to the google play store website. "wi-fi tether" comes back with a lot of results.
if they are os settings. where do i find them?
thanks
mike
I've had this happen too and my fix was to disable the wireless connection on my PC and then enable it again. After I did that it could then see the network being broadcast by the phone. I don't know why this solved my problem, but it did.Did it. now it starts without errors, but laptop can not find the wifi.
