Goo manager notified me of another update, but I'm 300 pages a lot of pages behind after a day of not looking at the xda thread. (I misread total page count). I wanted to keep track of important posts from there for myself, and I figured it wouldn't be much harder to flesh out a fuller FAQ from that.
Demo video
The install instructions often referred to here, link to newer roms here. The later versions can be dirty flashed, but the gapps needs to be flashed every time. Don't use gapps from goo.
There were builds on 2/14, 2/15, 2/18, and 2/19.
Information about the new radios. There was an old version ending with .33 to a new one ending in .48 that came with android 4.2.2. .48 disables LTE if you were lucky enough to have it and is not compatible with android 4.2.1 (2/15 build). Benefits of .48 are not concrete as far as I can tell.
Bugs??
-HDMI out not working in 4.2.2 versions?
Other questions:
How to get extended desktop
-Hold power button, select extended desktop
How to use PIE with status bar
-Turn off extended desktop, enter hybrid properties from settings, swipe right, interface, set Nav. bar to 0%. You cannot get notifications in pie this way
How to get settings back to normal
-Open settings, Tap recent, Long press settings thumb nail, Tap hybrid, Max DPI (320), lowest UI layout (360p), apply
How to get battery % in status bar
-not implemented yet, use a theme. Blue mint was mentioned a couple times but I didn't like it
How does longpress to unlock work
-in 2/19 build, with widgets in full screen mode, long press on lock icon. Settings>lockscreen to auto full screen widgets
Does it work with franco kernel?
-Yes, if using a 4.2.2 build, use a 4.2.2 compatible kernel
What's the best version of franco kernel?
-no clue, someone else
Demo video
Bugs??
Other questions:
