Help Can you turn off the shutter sound?
Well, can you?
I like to take pictures at random places but not when people stare at me.
Is there a certain way I could disable this?
Thanks. First day of having it and its better than the optimus V.
It can be in other location, I don't know your phone, it's also not in that location on my Alcatel. If you have ICS and root, maybe you can enable the shutter sound menu (which is disabled by default in most phones) following this guide :
http://androidforums.com/samsung-galaxy-s3/583031-camera-shutter-sound-off.html#post4893780
Then you'll get the option to disable shutter sound directly in camera app.
http://androidforums.com/samsung-galaxy-s3/583031-camera-shutter-sound-off.html#post4889426
Okay thanks! Also, does anyone know how to take screen shots on your phone? I can't do "hold + home"
I'm also interested on how to take screen shots.
EDIT: Sorry, overlooked earlier post. I just came back to Android a week ago from iPhone. You still can't take screenshots in Android without being rooted or having an app? Kinda weak.
Try the suggested app, they claim it can take screenshots on some unrooted phones, on some phones it might need root, just install it, try snap and you'll see if it works withiout root on you device.
https://play.google.com/store/apps/...otapptool.free&feature=search_result&hl=en_GB
Yes, it's painful, but you can also take snapshot via ddms or adb (connected in usb debugging mode, turn it on in developers options) :
How To Take Screenshots on an Android Device - TheUnlockrTheUnlockr
[Tips] : Poor's man screen capture using adb - xda-developers
Is there another program that takes pictures in FULL RESOLUTION? Because silent camera takes it as 320 x 480 and its damn right small. As if the no auto focus was bad enough
Success! I finally renamed cameraclick.odd to .old and it worked! But I don't want to pay for root explorer. I don't know any apps that gives you permission like root explorer.
Well, can you?
yea you have too have root and i used rom toolbox's file manager and deleted the system sound
