Help Cannot change notification sound.
Hi all,
I'm having problems changing the notification sound on my Arc. The ringtone sound I can change without a problem, and the same with the message notification. It allows me to change it as normal in the settings, but just plays the same sound/one when a text is received? Not sure what I'm doing wrong, the same notification sound has been on since I got the phone,even though in the settings I can change it to something else!?Any advice ?
Good to hear that you fixed it, however that is concerning, I will see if I can replicate that here. In the mean time you may still want to run an update just to be on the safe side.
