Root cannot connect to camera
Melanin_M
So ever since I rooted my Admire I have received this message. I've tried using multiple different roms in order to gain access to my camera back and have had no luck. I have done nothing extra at all. I literally used my camera right before rooting and after I rooted it, the camera stopped working.
Rebooting, clearing cache, clearing data , factory reset
None of the above have fixed the issue. Can someone please help me???
NO damage has been done to the phone in order to cause this. I've even tried downloading other camera apps, that doesn't work either.
whats version of GB are you on? 2.3.4 or 2.3.6?
try restoring from a back from here
http://androidforums.com/admire-all...-cwm-backup-odin-returning-stock-2-3-4-a.html
I have no clue what to do. I used odin to get back to 5.0.2.7 yet I still can't restore the stock
I've factory reset my phone, I've tried everything i can think of and the MD5 mismatch error still shows up ...
have you tried to use odin to flash stock?
you have to restore those backups with CWM 5.0.2.7 not 2.8
if they dont work then try the ODIN
i fixed the mounting system issue by flashing the rom back on my phone . Now im back at square one lmao.
I apologize for making this so complicated. If someone can give me some instructions on fixing the MD5 mismatch error I would highly appreciate it.
So far everything with odin has failed .
