Help Cannot connect to Wi-Fi
felix822
Member
I used to be able to connect to Wi-Fi with no problems. But all the sudden, the phone can no longer connect to any. In the Wi-Fi screen, it keeps saying "Scanning..." then "Connecting..." and then "Disconnected". Has anyone experienced this before?
I tried to Forget all the remembered networks and retyped the passwords with no luck.
Might try going into the manage applications screen and clearing the data from "settings". You will obviously lose all your saved settings.
The next step might be to try is a factory reset, unless you can think of an app you've downloaded that might be affecting your wi-fi.
Can you connect to open networks?
It's very possible you are having a hardware problem.
Thanks, I will try that. Not sure about open networks yet, the one here at work is secure.
* Edit: Clearing the data from settings did not help.
Mine has been doing the same thing since around the day that the clock jumped forward. It was previously able to conect to my secured Wi-Fi but not any more. Although it did briefly last night while I was sitting 2 feet from the router. I have yet to try connecting to Wi-Fi that is not secured. A hard reset did not fix the problem for me.
