Started last night. But I meant to add I'd given up JuiceDefender, and tried Green Power - both have been deleted, but I think the damage has been done.How long has this been going on?
It's restoring now. Will it bring back my phone-based contacts, or will I have to reenter them all? If I do, I may bag it and just go to importing them all into Google and be done with it.
I've got his earlier program, OCLF, that's how I rooted before. I'll download/install the newer one now (paid for, I support!!)![]()
Off topic for a sec, but CapFAQ's warning (There are any number of "lag fixes" out there, some better than others, all with their own gotchas, bugs, and ramifications) has scared me away from using any lag fixes. I understand, though, that some use OCLF just for the root function.
Thank you for all your help!
Jack, I didn't use the OCLF to install the lag fix, just to root the phone.
As it stands right now I'm back up and running, although JuiceDefender came back, and since I believe many of my issues stemmed from that program, I'm going to kill it.
I am having a bit of trouble keeping my wifi connection to my home network, it keeps forgetting the password. Grrrr.
What a PITA to get all the widgets set up again, and all the little tweaks I had made - oh well, I played a lot, maybe leaving most of that alone will be a good thing
No, the issues with JD started before I tried Green Power. So, neither program is going to be installed for now. The Comcast outage definitely is what caused the Wifi issues.I looked at Green Power and this was one of the comments from a user:
J
6 days ago
When green power service is running it prevents my 3G feature being enabled or disabled. Can't use 3G at all till I turn off serivce..uninstalled.
Could be that Green Power was the culprit of your not being able to connect to 3G. And the Comcast outage may have caused the problem with your wifi. (It certainly did on mine and on my laptop, too.)
Yup, I liked it too, until I started to get the errors that showed up in the log as 'fatal errors' and was told to uninstall and reinstall. I did that, and the ASOP Helper App couldn't be installed, thus rendering the program useless.I'm *not* affiliated with JD in any way. I just really like the program.
I hear ya, I hope you never start having the fatal errors I got.I just had a hard time believing that was the cause of your probs as I had absolutely no issues with the app since I started using it, a day after I got my Captivate.
I rooted the phone two weeks after I got it, and enabled sideloading two weeks after that - both long before any of these issues came up. I really don't think they're the issue at all or many, many others would be having the same problems. No custom ROMs, no lag fixes, nothing like that, just rooting and sideloading.But I am UN-rooted and don't do any sideloading. So the rooting and sideloading you performed on the phone could have destabilized it in some way. Just a guess. I'm just a chicken with rooting. Sounds great, even a status symbol perhaps, but I rather stay on this side of cautious.
Rooting is well worth it. Sideloading shouldn't have to be done at all, AT&T has no right to block app installation like that. YMMV. And I think it'll be a very cold day somewhere before we get Froyo.Waiting for the Froyo update to happen before I start investigating the benefits of rooting in earnest. I like the idea of being able to do a full backup using Titanium.
Thanks. I like it much more than my original bookstack![]()
No, things were futzed up anyways, obviously, because the 3G was definitely gone. So, it was a good exercise and lesson. Plus it let me learn more about the phone, and also to reorganize my screens. Cleared out the dreckYikes! So the reset / restore was just a practice drill.![]()
I did learn one valuable lesson there, the software that comes with the Cisco E1000 is web based - what the heck good is that when you've got no internet?
However, the three hours it took me to uninstall and reinstall the home network was definitely a practive drill![]()
