Cannot make the Wireless Connection. Help!
Night Train
Linksys 802.11n 2.4Ghz Droid Incredible I've gone through everything possible and can think of nothing else to do. Any ideas that have worked??
Short of returning my new "n" router and going back to the "g," is there a workaround or some solution? May this OTA some poster referred to will support the "n" standard?
I know it's not the phone...went to the mall last night and it connected easily with the hot spot at Borders...
Bump for the daytime crowd....
Has anybody successfully connected to an "n" wireless router system with their Incredible? If so, how'd it go?
Wireless-N hasn't been enabled on the Droid Incredible yet; however there is a setting on your wireless-N router that allows you to enable Wireless-G/N mode.
Check your router's security. If it is set up with a more advanced type of security, it may not be compatible with the Incredibles ability. Even try to reset the router to default and connect to it being unsecured.
Got it.
I reset the router to "g" and downgraded to the WEP secured 128-bit encryption. Now it's on the wireless and the web-browsing performance is blazing fast.
Lovin' it. Thanks for the help!
