Help Cannot recieve calls
chaos3232
Hey everyone, here I am yet again with another incredible 2 problem. So, here's my current problem. I can send and recieve text messages no problem and make phone calls no problem. When someone calls me and I go to answer it, I get the phone call notification, I get the error that process com.android.phone has stopped. Then my phone signal jumps into roaming and then I get my signal back. Any ideas?
I'm currently running miui and I've never had some many problems with a rom before. Should I just flash the rom and put CM7 or anything else on it instead? Really don't wanna go through another wipe process >_>
Thanks in advance, I appreciate it
First thing I would try is reflashing the current rom zip over your setup without a wipe. That way you don't lose anything and it should fix most system problems if the rom zip is good and the miui version is good. Which version are you running?
Pretty sure it upgraded to that beta one automatically the other day which is most likely the problem now that I think of it. Can I reflash to the current rom but a previous version without wiping?
Oooo, I don't know about that. I suppose it's worth a try but I would be prepared for it not to work and for you to have to do a wipe.
MiUI shouldn't upgrade itself, so be careful.
I had this same issue, my fix was ROM Manager > Fix Permissions. Let it run and bam! You're good to go. Idk if this will help but its worth a try.
