Help cannot restore phone please help!
At the top of the hboot screen it says "***locked***" when I try to restore it by selecting factory reset it doesn't leave the hboot screen and freezes. Please help!
Had that happen before after using the htcdev unlock tool. Had to use a stock ruu file, basically reflash the phones software. Google is your friend on that. Seen plenty of posts with good directions out there. It may not ne the best/only solution but its what I found, and it worked.
