Help Cannot same images by right clicking?
Knight5
Hey, previously I was able to save images on my note 2 by just clicking, holding my finger there for a second, and then a window would show up with several options and one use to be to save the image.
For instance, I could google search images and then right click them and save them.
Now, when I click and hold my finger down, nothing happens. Is there an update I am possibly missing or maybe the newest update messed up this option? I need some help because it is really frustrating having to screen shot everything and it shows the little tab for the dual screen option.
Thank you!
You should be able to long press the image and the options pop up. Which browser are you using?
