New to the whole rooting thing...
I was able to (i think) root w unrevoked3 and then unrevoked forever. I then installed the leaked 2.2. If I remember correctly, i had to root again after the leak.
Now, when I go to try to remove bloatware, by booting into clockwork and using adb, it wont let me in clockwork mod. I get the battery symbol thing with the exclamation mark.
I have S-off.
Should I re-root, is that the problem? What else could it be?
I also installed ROM manager, and it states that superuser was not found at "/system/xbin/su".
Should I assume that the update killed my root and I need to do it again?
TIA
I have S-off.
TIA
