Can't change camera settings?
pmcneil
Hey all,
I have two Samsung Transform Ultras from Sprint. When I try to adjust settings for the rear camera, almost all of them are greyed out. I can't turn on the led flash, adjust white balance, etc. These settings seem to work for the front camera though.
I've followed the manual, which indicates I should just be able to change all of these settings.
What am I missing here?
Patrick
Check your settings, if you are holding your phone in landscape its the screen button on the top, if in portrait mode its all the way to the right..
It says focus mode and then exposure.. scroll down that list more to choose scene mode and make sure auto is selected. Some if not all of those modes will not let you select specific options.
