Help Can't change camera storage to SD card
jaydee77ca
Hi,
I just put a new 32 gb microSD in my Samsung Captivate. I was recording a video after and got a message saying "Unable to record. Resolution not supported by memory card." Now, when I go in to the camera settings for both pictures and video the Storage option is set to Phone and I can't change it.
I never had this problem with my 16 gb card. Both cards are made by Lexar.
I copied my data from my 16 gb card to the 32 gb card before I dropped it in the phone.
I checked in the phone settings and the 32 gb card is mounted. The apps that are on installed on the 32 gb card all run properly and I can see the other files that I copied over. Android System Info shows the card is present and shows the proper capacity and space remaining.
Has anyone experienced this? Can anyone help? The purpose for getting the 32 gb card was so I'd have more room for media so I'd really like to solve this.
Thanks!
What class is the new SD card? I think it needs to be a class 6 or higher to record the higher resolutions.
It's a class 10. I rebooted a couple of times and unmounted and remounted the sd card and now it seems to be working. *Shrug*
Thanks for the reply! :)
