Help Can't connect to Kies [ICS]
Hey! I got ICS last week but after the update I can't connect to Kies. I keep getting a pop up saying:
Reconnect the device in Samsung Kies (PC Studio) mode.
Current connection mode not supported by Kies.
Check USB Settings.
(Settings -> Applications -> Development -> USB Debugging(x))
Any solutions?
what launcher are you using? for me kies doesn't connect to my phone when in another launcher. you have to uncheck usb debugging.
I had this a couple of weeks ago. I did a lot of research and armed with all me new found information 3 hours later I plugged my note in to do battle - and it worked without me doing anything!!! The only thing I can think of is the use of a different USB port and a different driver was installed although I still use the original port and it works fine.
According to my research the Note doesn't have a PC studio mode anyway so just another bizarre Kies glitch. Keep trying and it will go away (well it did for me)!
On the plus side I know a bit more how Android works.
Thanks for the help!
I decided to uninstall Kies and download Kies again via the Note Support Page on the Samsung site. I also used another USB port and bit all seemed to work fine.
Technology is so temperamental!
I cant able to get u... can u explain me a little bit elaborate...
