can't connect to Wifi
usualwyy
5
0
36
Nanking
dear all,
After I reboot my Desire,it stay in "obtaining IP address from xxxxx" for a very long time,and will never finish this work
Why?
here is the Wifi software version and screen shot when it working
Anything I could do about that? Please kindly advise.
Thank you!
dear all,
Why?
Thank you!
Have you tried rebooting your router & then trying?
Another thing to try see if you can connect to your router unsecured just to make sure its not your key playing up, if you can connect try using a shorter key
Upvote 0
thank you for your kindly help
It seems that you got the key :p
Actually I dont wanna restart my router everytime before I prepare to Wifi my Desire :(
Do you have any better advise :(
Will it be better if I flash the Wifi radio to Higher version :thinking:
Upvote 0
Thats always something you could try a higher version of wifi, but you may also find that the router reboot may have cleared the problem long term.
I find routers & all computer based products can get quirky through static build up, often caused by weather conditions.
Often a reboot clears the problem long term.
Upvote 0
BEST TECH IN 2023
Smartphones
