dustincole1992
All the kk are good I liked Kandy kat I'm on cm 12 now
Is cm 12 just as good as cm 11
Again man its all subjective YOU have to flash a ROM in order to know if it works for YOU. What's not important to John Doe may be the only feature you care about, vice versa. Make a backup, get a good data connection and get flashing lol, that's the only way YOU will know what's best for you. [emoji106] [emoji12]Is cm 12 just as good as cm 11
What he saidAgain man its all subjective YOU have to flash a ROM in order to know if it works for YOU. What's not important to John Doe may be the only feature you care about, vice versa. Make a backup, get a good data connection and get flashing lol, that's the only way YOU will know what's best for you. [emoji106] [emoji12]
The awesome ROM is Good and the kks are good and the cm12 has good battery lifelol this is so hardI can't decide on a ROM? I like L awe rom its perfect just battery life. and I can't get the data arrows to show for 3g or wifi
All I can say try one of u don't like it then try another one till u find one that best fits ur needs good luck there is plenty to chose fromI'm a social guy, no games
Most Custom roms will have it. If you're KK or below I think there's xposed modules that do it.thanks, do you know how to get the data indicators in the 3g and wifi
Google it rember Google ur best friendcan you tell me what xposed module it is? and I think I'll stick with L awe ROM. what kernal should I use for battery life?
Good glad u found somethingI am using cm11 kitkat , i found it stable and works for my needs. I have flashed many custom roms in past, settled with cyanogenmod.
