I was able to flash Myn's Rom, Wimax/radio update and, the transparent notification bar. For some reason or another, I can't flash the Launcher pro. Any suggestions????
Literally, nothing. I can see it in the Astro folder and, i can access it but, I can't install it. I've flashed it using ROM Manager and I've also tried it by flashing it manually. Nothing.
What do you mean by you can't install it? Do you have the actual flashable zip? Have you tried just flashing it from recovery? Do you already have launcher pro installed? If so, you need to uninstall it, first.
