Root Cant flash xoom
mohfath
Hello guys,
I got a serious and frustrating problem here.
A few days ago my xoom was stuck on the M screen, so I used a thread in the forum and recovered it.
It solved myh problem back then, but since I had 3.2 before this and the solution injected me with Android 3.01 my problems started to show themselves.
the first one is that
<b> Through Fastboot, RecoveryMod, ADB </b> and any other way you can Imagine to install a new ROM or even remove or create a file,
All of them show success message but when I check them out I see no changes.
I tried fastboot and Recovery to install nearly every ROM,Recovery and bootimage in this site but so far it was wild goose chase.
so I want to ask if I'm doing anything wrong or if you need any more information here, but please help me with this
Edit: for the sake of clearity I should add some info:
1. I even tried stock ROMs but you see I cant even flash them (Not from Recovery nor Fastboot) the steps seem successful : it opens the package,it installs them and it says everything was a success. But when I restart the device I see nothing has changed.
2. OTA updates are the same, they keep downloading and when the sysem reboots to recovery to install them it cant find them.
3. You dont believe it if I say even files and programs that I remove from device by my hand(Android OS) are back after the first restart.
And you see it's dark magic! everything from a file to a partition are back by one reboot. I dont know what should I call it but I havent seen anything like it on the whole Internet.
These are the procedures I take to flash a ROM, Did I do anything wrong?
1. I plug the Xoom to the PC using the included cable
2. I start the xoom and start fastboot
3. on the PC system has the drivers and completely knows it
4. I start with SDK:
I. Fastboot oem unlock (Completing onscreen instructions and reboot device)
II. Fastboot mode again I use Fastboot flash boot boot.img
III. Continuing with Recovery,System
IV. Rebooting the device anything is the same.
My ROM is unchanged by the process and keeeeeeeeps giving the damn error of System process error please submit
5. And with ClockworkrecoveryMod I have the stock ROM on my sd card.
I. I choose install zip from sd card.
II.Choose the correct zip file and start flashing.
III. Choosing Wipe Data/Factory reset will take the device into a complete hang. unless I first use the mount page to mount the System/Data
IV. I reboot the device and ..... you know nothing changed.
