AMTrombley0924 Android Enthusiast Jan 8, 2011 #2 are you asking on HOW to 3way call or do you already know the method and it's just NOT WORKING like it's supposed to?
wrightcomputing Lurker May 10, 2011 #3 Here is a link to all the call settings for the droid https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/48578/~/droid-x---calling
S scotthanna Newbie May 10, 2011 #4 works fine. simply hit add call, then dial or search number, send you then need to hit merge calls, i'm guessing that you are not 'hiding" the dial pad on the second call so you can go to "merge calls"
